Hi-psi
Ok, so, my understanding is that the downstreams are for the most part there to measure the effectiveness of the emissions control components and that the upstreams are primarily the values used for drive-ability, air/fuel management.
Where I'm going with this is as I gradually work through little job after little job on the '08 Denali I picked up back in March, coming up soon I was thinking of replacing the upstream oxygen sensors.
For the most part, it runs/drives fine, no codes. It does have an occasional stumble at idle. I've read a bunch of people saying that's just a tendency of the 6.2, others saying that a working, but lazy oxygen sensor can cause it. I also will sometimes get a little bit of part throttle under heavy load detonation. It isn't a fuel quality issue as I only run 93, and only from top tier brand/stations. Fresh plugs, wires, air filter, new fuel pump, etc, so, to me, it's got to be a fuel delivery issue.
Is it better to just replace all four sensors or would I likely see whatever benefit (if any) that I would get by just replacing the upstreams?
Just interested to hear anyone else's thoughts or similar experiences.
