Using Dexron VI instead of Dexron III
lumberjack890
Doing the fluid change on my transmission for the first time ever. 287k miles.
The fluid it takes is Dexron III, but can I use Dexron VI since that's all that I can find at auto part stores? I've been told they're compatible
I got the full synthetic both times I replaced my transmissions. If you’re not doing a complete change as in replacing the trans I would get the blend since that’s what’s in it from the factory as in DexIII.
L
lumberjack890
Ok thank you. Appreciate it
treehan77
TYF Fiend
Crestview, FL
That’s why I’m here, to see if “should” works out for you. Mines 191k and I doubt the PO changed it.
haloOne
