400K_or_bust
Searched until my brain hurt and still have a few questions on which wire mates to which
I just bought an 04 Yukon Denali SWB then went and got the Kenwoos DDX8905S DVD receiver along with the PAC R5-GM11 harness to retain my steering wheel controls, OnStar and so forth.
I've soldered and applied heat shrink tubing from my PAC R5-GM11 to the following wires on the DDX8-95S HU:
1) All 4 sets of speaker wires (white/white_b, gray/gray_b, green/green_b, purple/purple_b)
2) Illumi (orange/orange_w)
3) Ignition wire (red)
4) Both Yellows from R5 to Yellow from HU
5) Both Blacks from R5 to Black on HU
What I am left with is this:
on the PAC I've got:
1) a set of 3 wires bundled that are labeled NAV (salmon, purple_w, teal_w)
2) A pair of wires (blue/blue_w) that are part of the bundle that is in the connector that plugs into the "Radio Connections" port on the R5. The blue_w wire has a label on it stating it needs to be connected to the "remote wire from aftermarket radio for audio output"
3) A plug that goes into the steering wheel controls port which has a 3.5mm jack as well as a single blue/yellow wire. The manual for the R5 tells me I use the wire and NOT the 3.5mm jack.
On the HU I've got:
1) A blue_w wire labeled P. CONT. HU manual says to connect to optional power amplifier
2) A blue wire labeled ANT CONT. Manual says it's for antenna control and to connect to either control terminal of power antenna or power terminal for booster amplifier. I'm assuming I do not use that wire as I do not have a power antenna.
3) 2 green plugs labeled CAM- and CAM+. Proprietary Kenwood b/u camera is referenced here.
4) A light green wire labeled PRK SW.
5) A purple_w wire labeled REVERSE. Manual says for optional rear view camera
5) A blue/yellow wire labeled REMOTE CONT
Thanks for reading this far...What a bunch of word soup I've written.....
Bottom line is I think all I have left to wire up is the blue/yellow wire from the R5 to the HU REMOTE CONT and then I am done and ready to pull my old unit and install the new one?
I just don't want to blow this thing up. That quote I got from the stereo shop looked kinda enticing a few times the past 2 days as I've tried to figure this thing out..
TIA for any and all help.
Few pics to help illustrate WTF I'm trying to say are below.
On the HU I've got:
