Vette survo
Max
Mile High
Denver
I can barely get mine on the lift at work. Have to slide the arms under the truck, extend them, then put the feet on, then I can roll the truck forward and position the feet correctly. Should be alot easier with some airbags.
axekick
Austin, TX
What's the difference between AWD and my Auto 4WD?
Also, what difference would the 4th gear servo make? I'll probably do it just because it's so easy to do.
NathanJax
Vacation Nathan
Administrator
Jax, Fl
AWD is all the time 4x4. We can't change it. Auto 4wd has buttons to go to 2x4 or 4x4 low or 4x4 high if I remember correctly.
4th gear servo tightens your shifts into 3rd and 4th...
Tahoe03mm
Tahoe03mm
Puyallup, WA
I plan to do this nExt week. Question vette servo or billet? Also the 4th worth doing while I'm at it?
Max
Mile High
Denver
Just the vette servo is plenty. You'll need a built trans and 500whp to take advantage of the billet 4th servo.
2000Yukon
Nebraska
AWD is all time and the Auto 4WD kicks in when the tires lose traction and disengages until traction is lost again.
BOSS
The People's A D M I N
Dallas
Is it safe to put it in my 100K mile 2wd?
Take it for what it's worth, but a few members here have had issues installing a servo (or servo set) in a high mileage tranny (100-110k+). When I did my research before I had mine built out completely (3 times I might add LOL), shops that were building racing 4l60e's and a tranny parts wholesaler told me it's about a 30% chance you will have a problem post servo install if that's the only high performance piece you install.
B
Shadfrmdabull
