Vibrating fuel gauge
Crowder99Yukon
Fuel gauge wanders and vibrates constantly. Is there a fix or is it just the sending unit?
Sent from my HTC One S using Tapatalk 2
95escahoe
Common issue on the OBS trucks its probably a bad gauge the stepper motors going are pretty common, mines done the same thing for years, even after doing a fuel pump and sending unit
Sent from my HTC One X using Tapatalk 2
KPOD
Michigan
Yep same. I've just learned to always refuel after 300 miles regardless of the gauge. Normally when it's all the way on E, and even slightly past. I still have at least 3 gallons left though.
Crowder99Yukon
Crowder99Yukon
These trucks have a 30 gallon fuel tank I'm told. And at 300 miles I fill up with 20 gallons. And that's on empty on the gauge. So should have another 10 gallons
95escahoe
I do the same lol
GAyukon21
south
glad this is a common issue, i bought my yukon last week and was worried about a deeper electrical issue
SunlitComet
OBS Jedi-Do Good
unknown at this time.
the 98-99 run the fuel level sensor thru the pcm so it is not uncommon to see the pcm output causing the issues. the dampening fluid in the gauge dampens it out. for 97 and earlier unit the vibrating is likely cause from ac ripple in the voltage from weak diodes in the alternator. or something to that effect. in regard to the wondering, in all years the 4 dr tank or narrow side to side and long from front to back with no baffling so wondering will always be there. 2dr are more square boxier so they are no as bad.
ihadtheories
