SunlitComet
OBS Jedi-Do Good
Pretty sure the diff isn't moving around. The other side fine, nice and tight. How do you suggest to remove the output shaft bearing? Slide hammer/bearing attachment?
Yes.
---------- Post added at 09:28 AM ---------- Previous post was at 09:14 AM ----------
I do not believe the engagement collar has anything to do with the issue since thats the first thing i thought of and rulled out. The DS does not move and center diff operates as it should.. I even tried rotating the from D/S alone nothing happened. The issue seems to be coming from the differential itself; along the lines of what nimrodcs is facing.
To answer your questions:-
1. I have 3 4wd buttons 2wd, 4hi, and 4lo.. No Autotrac.
2. The oil seemed to be in good state, its clean, smells normal and viscosity seems okay. Now having said that, i am considering changing oil in all 3 diffs anyway as cheap insurance.
NIMRODCS; To be honest i did not try tiliting the flange about.. I just rotated it back and forth and noticed the alternating friction.. I do need to try that though since it makes most sense since i've almost rulled out any external failure. I believe the issue is in the front diff..
Maybe time for 4.56 gears and 35s![]()
Well if you right wheel turns opposite of the other with the plunger removed then the collar must be catching on the two right side axle shafts or there must be a friction lock of some sort between the two. Otherwise the the right output shaft should spin freely of the the left one, driveshaft and diffy thru the disconnect point(#8 in the picture below).
