I have a 00 Tahoe, 5.3. I recently started noticing that my voltage needle is flickering a bit while idling and more so while driving. While idling, when I give it gas, the needle will drop significantly, lights will dim and truck will want to stall then go back to flickering again. Same thing while driving, the needle will flicker and as soon as I step on accelerator hard, it will drop and climb back up and flicker again. Here's what I've looked at and done so far,
1.) Checked and wiggled all connections and ground
2.) Alternator was tested and tested out fine, also have a new battery
3.) Changed the whole main tensioner assembly and belt
4.) Cleaned battery terminals and checked connections
None of the above have solved the problem
Is there anything else I can check myself or tests I can do? I'd rather try to fix this problem on my own before having to take to the shop.
Thanks!
Thanks!
