Alright guys, I come to you for your superior knowledge once more!
I hooked up the new 0411PCM and was having a high idle issue just like the last pcm. Somehow, it finally settled down and I did the crank relearn. FINALLY TOOK!!! No more issue there.
However, I'm using a Snap On Solus Ultra, changed the vehicle information so I could read for a 4l80e, and looked at the data... ISS reading is close to RPM value, TCC reads around -60 in P/R, 500-600 in gear. Transmission is starting off in 2nd gear, per the Solus, and I even caught it reading 2nd for a moment when I shifted into Reverse. Solus reads a 1-2 shift time of 0.03 seconds, as soon as I put it in gear. If I let off the throttle when taking off, it will stall and die. It will do that at times when I hit Reverse. Sometimes I shift directly to Reverse or Drive and it stalls immediately.
Took it out of the driveway for a drive around the block to see if it will shift gears. It is erratic, and shifts into 3rd way too quickly. Not holding gears at all, and starts in 2nd. I checked the voltage to the transmission, and I'm getting 12V.
Trying to think if any other information to give you guys. I still have the Solus, so if you guys need any other information, I can get it for you.
Also have a leak at the tail housing adapter as it connects to the transfer case. Leaks pretty significantly. A drop every 10-20 seconds or so. I wouldn't think this would cause a significant enough drop in line pressure, but maybe I'm wrong? Transmission temp only reads around 120-130
