Want stiffer ride/lift
autolover3
Bismarck/Wahpeton, ND
My 99 seems a bit soft to my liking. Curious if some add a leafs in the back and torsion keys up front would help. But I myself am not a fan of just adding keys and cranking on a stock front end. Any others do something like this?? Not looking for a big lift just something to maybe fit 33's and a stiffer ride.
I also found this kit on NTW online.. any input?
http://www.ntwonline.com/Suspension...-3-Inch-Special-with-Shocks.html#.UrPP5eKp93E
BigDaddy13440
Rome, NY
No need to add keys, unless your bars are worn - just crank your stock keys an inch or so... do not max them out, or you might as well get a job at an auto parts store, you'll be replacing the ball joints, tie rod ends and pitman and idler arms yearly.
As for the rear, add a couple leaves from a junkyard to each pack. I put 3 leaves in mine, gained 2- 2 1/2", and it's MUCH more stable and tighter thru turns.
autolover3
autolover3
That is why I was curious with cranking the stock front end... I'm not looking for a big height raise but don't wanna stress the front end too much. Will stock length shocks be enough if i were to add some leaves in rear? Would I be able to clear 285/75/16 tires if I did this?
Thanks for your input!
BigDaddy13440
Rome, NY
Stock shocks are fine, no need to change. 285's fit on stock wheels, or aftermarket with stock offset - mine were positive offset, stuck out almost 1 1/2", had to trim the rear of the front fender, and clearance the bumper and valance so they wouldn't rub during compression. I had mine cranked about an inch or so, stupidly cranked them to the max to clear everything - replaced my BJ's and pitman and idler arms 3 times in 4 years before I wised up.
When I did my rears, I used leaves from a Suburban, and slipped a leaf in between each stock leaf.... Cut each one on a metal chop saw so the length of each leaf was shorter than the leaf above it in the pack, NOBODY would know that it wasn't stock unless they were another TYF forum member (not even the techs @ the garage I take it to knew). In addition, swapping in extra leaves also adds to the load carrying capacity... I also swapped in beefier leaf spring hanger brackets when mine started to crack.
Just an FYI... I carried 40 pieces of 12" wide x 17' long rough cut strapped to the top, and I wasn't even close to bottoming out. Each one weighed well over 40lbs, probably closer to 50lbs. Previously carried 24 sheets of 1/2" plywood, 18 2x6x12's, 5 rolls of torch-down roofing, and 3 rolls of roofing felt, without bottoming out. Also towed a 9000lb Komatsu backhoe on a 20' trailer, no worries about swaying while towing @ 40mph....
EdTuck
