Washer fluid leak
Jobi-Wan Kenobi
I have a washer fluid leak in front of my drivers front tire when I try to clean my windshield. From what I've found so far the tank is the likely cause. I can't see anything though laying underneath and don't want to take it apart to find out since it's my daily driver. Should I just figure on replacing the tank?
Scottydoggs
NJ
likely the line from the pump. known for breaking.
Jobi-Wan Kenobi
Jobi-Wan Kenobi
Shouldn't have froze. I don't even bother running a summer formula so I don't have to worry about it freezing when we start getting freezing temperatures.
There is a coupling on that washer line in the engine bay on the inside of the driver's side left quarter panel above the ECM which is a friction connection. I've had mine come apart, and the washer fluid drains near my front left tire.
Jobi-Wan Kenobi
Jobi-Wan Kenobi
Found the leak. I think I broke the line when I was changing my battery a couple weeks ago.
brian70068
