Washer fluid leaking from rear of 2022 Tahoe
Max2013
Anyone ran across this before? My 2022 Tahoe has started leaking windshield washer fluid from the under the passenger side rear of the vehicle. A quick look shows the blue fluid is dripping out from a flexible electrical cable conduit. Evidently the leak started up around the washer nozzle and the fluid has made it way into a conduit and has ran down to the low point just under the passenger side exhaust pipe tip. Just wondering if anyone has seen this problem before? Here is a photo of a clear bowl I placed under the leak, just so I can show it to the Chevy folks.
Big Mama
Virginia
Welcome to the forum from Virginia. Some folks with newer rigs like yours will chime in. If you refill the reservoir does it leak constantly or just when you use the rear wiper/washer?
Read this thread to see if it applies.
M
Max2013
Thank you Fless. I will drop the spare tire and take a better look. Will report back what I find.
schimme
