Water leaking from under the dash?
dapope125
I cleaned out the AC drain hole last weekend by blasting it with air from a hose for a solid two minutes.
Unfortunately, that didn't fix it.
It seems to really get wet when I have the AC on full and max cold.
Any ideas, guys?
dapope125
Alright, Thanks.
I noticed when I don't have the air on "Max Cold" the water doesn't drip.
I'll try to find the Evap this weekend.
Harlech
I am a robot.
Texas
Yeah, you may have just been stirring up leaves when you were blowing out the drain hose with air. When my evap box leaks it's pretty easy to see the source, it's from the right hand back side of the box.
But the clean out is super easy to do, just make sure to put a towel down when you hose it out with water. Forgot that step one time...
