Water Pump Failure
HomeMadeSin
2018 Yukon XL Denali, 79k miles on the clock. Making the trek home from southern FL last night (27 Dec 2024). About an hour and a half left to go, I start hearing a chirping sound. Inconsistent but definitely noticeable. Had the Mrs, cat and Xmas stuff so my plan was to listen and watch. For a while, the temp gauge was fine. Then it started edging up…so I slowed down. This helped move it back to 210F. I knew the fans were plastic but I kept thinking something was hitting the blades. Just 45 mins to go….
And then the temp climbs to 260 and engine dies. Insert FAFO stamp on my forehead for trying to nurse it home.
Got a tow from the darkest shoulder in I-95 (it seemed) to a very small town repair shop after hours. Bottom line: failed water pump. The WP pulley was loose and caused a near total loss of coolant and the serpentine belt slipped off.
Already repaired and working ok. Just a bunch of coolant in the engine bay, driver side. Just never had a complete failure of a water pump before. Lesson learned.
Z
Z
ya these "modular" water pumps on the k2's are not the greatest, but at least they can be repaired rather easily and cheap compared to having to replace the whole pump manifold assembly
That's a rarity! Glad the motor didn't drop a valve seal after it got hot. The previous generation 6.2s were known for this.
What town did you break down at?
i got lucky with mine and caught it "dangling by a thread" and managed to limp it a few miles to the dealer under warranty @36k.
I heard it making noise previous to that but thought it might be the vacuum pump since it is right behind it.
H
HomeMadeSin
We wound up coasting to the shoulder of I-95 about 1.5 miles north of the South Newport exit. The tow truck took us to Riceboro.
The auto mechanic was on it the next day (yesterday) ASAP and had us running by 2pm.
Just changed the oil and things seem to be running well so far.
Z
CMoore711
@HomeMadeSin Almost the same situation just happened to my wife's '19 Escalade ESV w/ about 74K on the clock a little over a month ago. Luckily she was less than a block away from home when it occurred. She slowed down and babied it <25mph, then once she turned onto our street the water pump let go and leaked coolant from the end of our street (about 5 houses down) and into our driveway.
Towed to local Cadillac dealer that night. Water pump pulley failed became misaligned then the shaft finally destroyed the water pump. Luckily she was close to home and it never over heated.
It was also our first experience with a repair on the aftermarket warranty we purchased; It ended being about a $1,200 repair at the dealer and we were out $425 for misc. items not covered. Apparently when the pulley became misaligned it managed to wear off the head of the mounting bolt for the water pump, so there was additional labor in removing that bolt that the aftermarket warranty wasn't willing to cover. Bull$hit I know... Fluid and belt weren't covered either. I tried to push back; "But for the water pump failing there would be no need for new coolant, a new belt, or the additional labor for the ground mounting bolt" But they ironically weren't seeing that correlation.
It could have been a lot worse, but was also just very shocked to have a water pump failure at <75K miles.
Josejr00
