weird blue box behind radio
HACK BLOCK
NYC
found this stuffed behind the cluster when i took out my radio. it was spliced into the radio harness
NathanJax
Vacation Nathan
Administrator
Jax, Fl
Looks like the box you need for the chimes when you put in an aftermarket radio.
Nope
It's a AUX box that hooks to the radio to give you iPod hookup. uPAC-GMC2
images
H
HACK BLOCK
NYC
scanned my car today and got these 2 codes. my steering wheel controls don't work so u think this? could this be from the PAC aux box? anybody think if I remove it I'll be able to get back my steering controls
NathanJax
Vacation Nathan
Administrator
Jax, Fl
This box has NOTHING to do with any codes that would pop up.
Do you have the OEM (factory) stereo installed or an aftermarket?
If it's the OEM radio, you need to make sure all the factory plugs are plugged in.
If it's aftermarket, you have to have a box (kinda like that one) to get the steering wheel controls to work again.
H
HACK BLOCK
NYC
factory Bose radio and everything was plugged in when I checked but I'll check again
H
HACK BLOCK
NYC
U1000 - class 2 data link malfunction
U1096 - lost communication with driver information and display controls (DIC)
H
HACK BLOCK
NYC
checked the connections again everything looks good. i even removed the PAC and still doesn't work. I noticed a couple of taps inder the cluster near the steering column not sure if they are supposed to be there or not.
tators50
