Weird sound coming from front driver wheel
Havic26
When I go to make a left hand turn there is a strange noise, like something is rubbing up against the wheel or something. It sounds like when you put a card in the spokes of a bike. What could it be?
drakon543
Wheel bearing, axle/cv joint, something rubbing your tire but only right on the edge where it woulf be able to make that sound.
MrBalll
West Texas
Check your inner fender well. Maybe it came loose.
Have someone else steer the car slowly and you walk with it and look and listen.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
Check for something Stuck in the backing plate of the rotor. For me i live in NE so when i had a similar noise, I had rust that built up on the edges of the rotors that the pads don't contact. My rust ridges would contact the caliper bracket on hard turns.
Jellis02
