Weird Suspension Issue...
RBTech
Hi everyone. I bought an 02 Tahoe last month with 113xxx miles and have been fairly happy with it. It's 2wd with the 5.3L.
Now here is the issue. The truck drives fine down a level road. If I come across some uneven roads on the passenger side, especially around a curve, the truck rocks pretty bad. The front end also visually shifts from right to left. The driver side doesnt do this, it performs normally. I have even replaced all shocks with sensatracs and it still persists.
I was thinking about tightening up the torsion bar bolt on the passenger side and see what that does, but other than that I'm totally perplexed. The alignment is just fine, tracks straight and true. Tires are all at 35psi. Tires are fairly new, no uneven wear.
What am I missing? Thank you all in advance.
groundscr8pr
flaccid member
scarborough maine
torsion bar will only adjust ride height. i would have all sway bar bushings and end links replaced and panhard bar bushings also.
Physh1
Def. check the sway bar bushings & end links...
RBTech
RBTech
Thanks for the replies. I will check out what you two suggested. Thanks for shedding some light on the situation :)
RBTech
RBTech
Finally had the chance to replace the endlinks yesterday. Old ones were literally falling apart. Much easier to replace than expected. Problem solved! Thanks again for the help :hands: .
a2015gmcyukonxlde
