Hello,
I thought I'd take my issues to the online community before I take it to the shop. I purchased this 07 Suburban (5.3) with all these issues for pretty cheap, so just trying to go through 1 by 1 and fix them.
List of codes currently have:
P0036
P0056
P0141
P0161
P0700
P0787
P1815
The symptoms I'm having is there's currently a little smoke coming from the exhaust during startup for a few seconds and goes away. I'm guessing that corresponds to the O2 Sensors.
Also, it will not shift to what I feel is past second gear. I can hit about 50, but it's pushing 3500k.
Gear shift indicator will sometimes not light. If you go down to Manual, nothing will illuminate, and it will act the same as in drive.
What I have done is replace the TCM, both shift sensors, the 3-2 sensor and Accumulator along with the filter and transmission fluid.
I have also replace both passenger side (I believe is bank 2?) Sensors.
Also, supposedly the transmission was replaced and it's always acted like this?
Really trying to focus on the transmission side of things to get it driveable, and then worry about the O2 things.
Any help would be appreciated, thanks.
P0036
P0056
P0141
P0161
P0700
P0787
P1815
