PG01
Yes it needs to learn,first start gonna be rough because of cleaner. Did you start it and sit in park and let it idle for 3 minutes then turn it off for 1 minute then idle again for another 3 like i posted.
Throttle Body Idle Learn Procedure GMT900
- Throttle Learn
The engine control module (ECM) learns the idle position of the throttle plate to ensure the correct idle.Anytime the throttle body is cleaned or replaced, the ECM must learn the new throttle position. The idle may be unstable or a DTC may set if the throttle position is not learned.
Conditions for Running the Throttle Learn Procedure
• DTCs P0101, P0102, P0103, P0107, P0108, P0111, P0112, P0113, P0506, and P0507 are not set.
• The engine speed is between 450-4,000 RPM.
• The manifold absolute pressure (MAP) is greater than 5 kPa.
• The mass air flow (MAF) is greater than 2 g/s.
• The ignition 1 voltage is greater than 10 volts.
Throttle Learn
Important: Do NOT perform this procedure if DTCs are set. Refer to Diagnostic Trouble Code (DTC) List - Vehicle .
1. Start and idle the engine in PARK for 3 minutes.
2. With a scan tool, monitor desired and actual RPM.
3. The ECM will start to learn the new idle cells and Desired RPM should start to decrease.
4. Ignition OFF for 60 seconds.
5. Start and idle the engine in PARK for 3 minutes.
6. After the 3 minute run time the engine should be idling normal.
Important: During the drive cycle the check engine light may come on with idle speed DTCs. If idle speed codes are set, clear codes so the ECM can continue to learn.
⇒ If the engine idle speed has not been learned the vehicle will need to be driven at speeds above 70 km/h (44 mph) with several decelerations and extended idles.
After the dive cycle, the engine should be idling normally. ⇒ If the engine idle speed has not been learned, turn OFF the ignition for 60 seconds and repeat step 1.
As an eBay Associate we earn from qualifying purchases.
