I have a 1997 Tahoe that I bought a few months back with a blown head gasket. While diagnosing my problem, I had the bright idea of sticking a screw driver in the spark plug hole of one of the cylinders to find TDC. The bad part is I used the starter to bump engine and my screw driver came out all mangled. Live and learn I guess. Anyway, Now I have a knock that I didn't have before. This is what I know.... Head had bent valve on that cylinder so I got another head to have checked and rebuilt along with other one. I installed new roller lifters trying to fix problem...no help. Piston looks ok. Compression is ok. Noise sounds kinna like top end but really hard to tell. Noise will quieten for about 15 seconds then come back if I tighten down on that valve. All I can figure now is that I wiped a cam lobe when I did that but I am wondering if their is a chance that that could have messed up rod bearing. What do you think? All input is appreciated.
