justchecking
Military
SW Ohio
Getting ready for a pheasant hunting trip to SD. Replaced my temporary duty spare with a full size 22” road worthy spare and made sure I had all the tools and they worked.
Here is the new spare and tucked away under the Suburban. The cardboard is under there because I sprayed some fluid film in a few likely rust spots.
CMoore711
@justchecking what size tire you got on that spare? OEM 285/45R22?
Can you post some pics how it looks from the back with a full size 22” spare back there?
Interested in how much lowered it sits below the bumper cover and ground clearance. I should really do this for Wilwood BBK at all 4 corners.
justchecking
Military
SW Ohio
So here's the deal. A few years ago a tow truck driver flagged us down because he had a chevy truck client stuck in the woods with a shredded tire and neither him nor the owner had the chevy tool to crank the tire down. So we drove in there and he used my tool to crank the tire down (it was a bear because the crank mechanism was all corroded up). Finally got the tire down and installed and someone noticed the "TEMPORARY USE ONLY" note on the sidewall (and as I recall the truck may have had aftermarket tires and wheels on it). Well, they had a couple hundred miles to tow a camper home and probably over max gross vehicle weight because modern hunters take EVERYTHING with them. So how far is too far on a temporary only spare?
So I make sure I am good to go with options.
My new spare tire is a Bridgestone Alenza 285/45R22 32.1" Dia with 11.2" section width on a 22x9 rim with same offset and setback. I went ahead and bought a new tire because the other four are brand spanking new. My OEM spare was a 265/70R17 with a 31.6" Dia and 10.4" section width. It was clearly marked TEMPORARY USE ONLY and also somewhere I saw DO NOT TOW WITH THIS TIRE. So the new tire is only .5" bigger in diameter and .8" wider. The picture I posted below tries to show that the differential still hangs slightly below the tire. Standing in back of the vehicle I could not really see that the spare now hangs 0.8" lower than it did before.
The previous spare rim was designed so it would not hold water. If you look closely at the picture of the new spare in the earlier post you may be able to see a small weep hole opposite the valve stem. That is oriented at the lowest point when the tire is cranked up under the Suburban. Any more questions, just ask!
RB_Trucker
Redondo Beach
Looks like I’ll have the pleasure of replacing this hose once I fly in from SLC today. Wife noticed coolant was really low and was dripping from the right front side… gotta be those factory crimp style clamps going bad already
2019 Suburban 5.3 117k on it.
doubtful, it's more common for the side of the radiator plastic to develop a small crack and start leaking
justchecking
Military
SW Ohio
I installed the dual battery setup from the 2011 into the 2019. I tried to make it look OEM as possible. There is nothing to see on the passenger side since the upfitter manual recommends running the positive cable to the starter positive terminal.
Tom15Tahoe
What I have done so far this year.
Air raid intake tube and engine cover
New wheels.
Power stop Brake kit for all 4 corners
Vland Escalade style taillights
Have had this Tahoe since new and it will be 10 years old next week. It was due for a little touch up.
RST Dana
OH
What’s the deal with that intake cover? Not factory.
Tgwest
