I have been through every nook & cranny in that truck. Obviously, finding the key is the single best way to remove the locks. I already dug through the tire remov' tools cubby looking to see what was present/MIA/check the spare tire & ratchet system.
The other 2 wheel locks of the set weren't even on the back tires because they had been replaced, while the front tires had not. My local stores don't carry anything that will help me.
Is it true that if I buy another set of wheel locks (which I have to do anyway) the key included will in no way fit the old locks still on my truck, even if it's identical make/model?? None of the stores even carried the same model of Dorman wheel locks on my truck. They have the same make/model, wrong size. Every size EXCEPT a GM 14x-1.5. How in the hell is that even possible. 1 store had a Dorman 14x2.0, same make/model & appeared to have the same lock & key pattern. It looked to me like it would fit but the store clerk thought I was an idiot for trying to buy the wrong size. PLUS.. all 3 kits they had on the shelf in 14x2.0 were taped closed, so there's no way I could return any 1 of them if the key didn't work; BULL$HiT!!!
What's the proposal for modifying 1 of my sockets? Grind it out to fit the pattern on the old locks? There's no way... the lug openings on my wheels are a closed design & super deep. The locks themselves are smooth @ the top 1.5" with the keyways design at the very bottom 1/2", so none of the wheel lock removers I found where not only too short, but also too large in diameter to fit in the lug hole. It's a screwed up deal; only a tire shop will have the tools to extract those things & even then I doubt 100% of them will have what is actually required. I don't want some bird brain tire tech using the wrong $hit & completely FUBAR the things. I will have to order a few dif items online if I'm to remove the locks myself, which is ideal.
