inmypassatlife
Already searched and didn't find anything regarding this grille, anyone have any experience or input?
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/372023369058
Trying to get all my add on items purchased before I begin wrapping my truck. Grille trim will be color matched to truck and I want to black out the grille. I am also retrofitting black housing headlights, possible quad retrofit depending on my mood. Lol
I have the same one. Well, not the same EXACT one, but basically the older version of that one. I have the 3160d and you have the 3160g. Main difference is yours has the bigger screen and it's a full color screen. My screen is the old ass black and blue screen. I've had mine for about 2-3 years now and I still don't know how to use all the features on it. But yes, the live data, ABS codes, and airbag codes all come in handy. I checked my Burban and even though my airbag light wasn't on, it pulled a fault code. Said something about "failure to communicate" or something. I reset it and it hasn't come back on since. And I was also able to easily pull the ABS codes on my Burban and my son's 99 Silverado. We both have the same code for a faulty ABS module. I reset mine and it is doing fine, but his KEEPS popping back on every time he drives the truck so we will have to fix his. And live data, I still don't know how to fully use it, but I have had it connected while driving and i could view my coolant temp, transmission temp, engine RPMs, and even vehicle speed. It's good if you want to see how accurate the gauge cluster is. Here's what my screen looks like. Nowhere near as cool as your full color screen. This was a code it was popping a few times right after I replaced my oxygen sensors.
What are all those bubble in the upper left? Are those the failures or possible trouble codes? Other then your P1133? Or do they show all the time? I'm not very patient when it comes to reading directions. I actually got this due to your recommendation @ScottyBoy :D.
ScottyBoy
Shreveport, La
Like I said, I STILL don't know what all this this does, or how to fully use it. That being said, I honestly don't know what those mean. But I suspect they are symbols that basically show what vehicle system the code is related to. I think that because those bubbles say things like "Fuel, Misfire, O-2, EGR, etc" and ALL of those systems are related to the oxygen sensors.
I just looked back at the picture you posted of your package, and yours has the SAME bubbles except two of them are red. But the red ones are related to the exhaust, so maybe that's why they are red? I guess we won't fully understand unless we read up more on the instructions and user manual. Lol
95escahoe
Went and filled up the Esky and took this shot at the Cadillac dealer that I’ve been meaning to take for months lol, once the weather is nicer and the trucks all clean I’m gonna go back and get some better pics
YukonXL04
The Riverboat
Arlington, TX
that is a insert, you can just slap it on over your existing grill or cut your grill out and give it a much cleaner look
Scottydoggs
NJ
picked up this tahoe a few weeks back, needed brakes bad. 121,000 on it one owner and the rotors look factory, the bracket bolts would not come out with a air gun, broke a ratchet, all 4 corners fought me on the bracket bolts, but i won!! looks las if some jerk off has been slapping new pads in only, front were damn near new looking when they came off.
truck brakes nice and smooth now.
new ish looking front pad.
https://photos.app.goo.gl/WRFKwiIqIWgjcFVr2
TBuKBory8aGD9Os53
all old junk, not the top edges are all rusted and not making any contact, a few of the pads were curved over the top edge.
https://photos.app.goo.gl/ksAKVL5412vIrzpo1
2HbskaDSCF8zV3od2
speaks for its self
4yUS31VZwmrT3jNb2
https://photos.app.goo.gl/jhjnxkUwamJLT3xq1
curve in pad
7S5ifKonKVxc2BMt1
https://photos.app.goo.gl/01XtQqwjSEOHPsB43
little more then 1/2 this rotor was making contact with the pad
https://photos.app.goo.gl/i6l1GEIMlVh1jyqv2
4wLeMrxuwrW6S9RI2
only installed pic i took, R1 e line drilled and slotted with ceramic scorched pads. i have these on my regal gs with f bodys up front and stock out back, best brakes i ever bought, so im doing it again.
https://photos.app.goo.gl/ciR4ZhNiwAIPiBwH2
and now it stops smoothly. i knew it had warped rotors lol
inmypassatlife
I understand that, but has anyone installed one here? Or a link to another forum? I've seen some installed on Google, but they are of those $1k+ grilles which is friggin stupid expensive
im sure there is a thread on here of someone installing one similar, just do a search or look in some of the build threads for "grill"
BMPGBH
