95escahoe
Finally got around to installing my corvette servo in the escalade. Only sat around in the garage for like a year.
Everyone should do this. Shifts are more positive, but not jarring. Trans temps stay a little lower and it reduces wear/increases service life thanks to less slipping
Where did you get yours from?
TheAutumnWind
The english fella in this YT vid gives a pretty good in-site to cheap ceramic coatings, and after using it I agree with everything in this video EXCEPT,..... he said his did not 'firm up' or harden as it should,... well mine did,.. AND,... I felt that resistance he speaks of when buffing it out. I will leave an ebay link to the one I bought, and Im defiantly buying a couple more. I felt like it worked quite well. (look he's got me talking in english brogue now)
Ebay Link - https://www.ebay.com/itm/Liquid-Glass-9H-Nano-Hydrophobic-Ceramic-Coating-Car-Care-Wax-Crystal-Car/282761657396?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
If you are not in a rush its on ali express for cheaper...
TheAutumnWind
Everyone always says to get it from oregon performance transmissions. They have an ebay store and amazon too iirc.
https://www.oregonperformancetransmission.com/mm5/merchant.mvc?Screen=PROD&Product_Code=NTP-K51828C
I think i got mine on amazon?
Yup here:
700R4 4L60E Corvette Servo https://www.amazon.com/dp/B0081H7E58/ref=cm_sw_r_cp_apa_5oQ2AbBY6ZTVD
Heres the one i had on my denali for a year.
4L60E 700R4 Corvette Style Servo Piston Kit GM https://www.amazon.com/dp/B009GNAZTI/ref=cm_sw_r_cp_apa_5pQ2AbN2FM2R2
They seemed the same to me.
HiHoeSilver
Away!
Chicago
Yup here:
Did you use the longer pin?
95escahoe
Yup here:
On the first site there is an option for an OD servo is that anything you need to add? In the past when I’ve seen this done it was just the Vette servo no mention of the other
Countryboy07
Yeah... I've had mine for about a year or so, and an HD hood, and denali head lights, and Klearz. Man I need to get busy!
TheAutumnWind
I didnt add it. Most people dont. From what ive read it isn't necessary unless you are hitting wot going into OD regularly,
Only took me 2 hours. I could probably do the next one in 30 mins. Its easy. Be careful with the e clip. Get everything seated all the way and in the right order. Thats pretty much it.
Took some fiddling to get the first spring to sit right and to get the cover to sit in all the way so i could get the big snap ring in place.
HiHoeSilver
Away!
Chicago
For you run into the heat shield /clearance problem at all?
