MannyB
British Columbia
Can you take a picture of the back of the headlights? I would like to see how the projector is mounted. I know anzo uses the same type of mounting points as stock. If these do as well k may pick up these lights and swap my retrofit into them
Will do. I'll try to get some pics up over the weekend
Massfloefi
Retrofit by Lightwerkz in NJ this morning.
Had to hit the adjusters with PB Blaster and the drivers side still wouldn't raise the headlight enough. At this point it only clicks when you turn it but no adjustment. Headlights are aimed to low. I was able to wedge something between the grill and headlight assembly to get almost another 1" but I still feel like there is more room for improvement. Looking for a set of used Denali headlights. Hopefully I can get adjusters that will go up adjust enough. I have heard that the Morimoto H1 have a sharp drop off and I hope that's not the case here. See below for what I am talking about.
This is just before I wedged something between the headlight and grill.
1992rs
OR
You’re cut off looks like mine. Did you use mh1 7.0’s? I wish I would of done a little more research before I did my retrofit because the mh1’s aren’t very good for distance and they put a ton of foreground lighting, which is the opposite of what I need with all my leds and fogs.
Thats cool you had lightwekrz do the retrofit though! They are legends. I remember finding out about them in 2010, when retrofits were more underground and everyone was running ****** PnP hid kits.
Bombsquad85
Northern VA
He did use MH1 7.0. I have the same retro ut mine doesnt drop off like that.
I do have the same strange cutoff like his wall shot.
I really wish I went with a d2s projector... I think it would have been fine trimming some of the housing theres an awkward lip that looks like you could easily trim it to fit a larger projector
inmypassatlife
foreground limiter
super_kev
