BADRIDES
- Joined
- Dec 18, 2015
- Posts
- 1,741
- Reaction score
- 1,159
Nice website
They don't seem to offer anything for the 02 Escalade cluster like mine.Boy, oh, boy..... That website is a candy store!! Nice prices...
Nope, 02 options are very limited as I found out a long time ago. I finally decided my Denali cluster looked better than the alternatives.They don't seem to offer anything for the 02 Escalade cluster like mine.
Yep, I did that too. The one good thing about 02’s is you can swap those easy.I went with blue LEDs.View attachment 243286
Couple hours lmao. Nice work.New:
- Pitman arm
- Idler arm
- Idler bracket
- Upper control arms
- Lower control arms
- Camber adjustment plates
- Camber adjustment guide pins (get the Moog ones, not Specialty Motor Products)
- Front and rear bump stops
- Inner and outer tie rods
- Driver's side wheel bearing/hub
- Front differential axle seals and bearings
- Replaced broken front axle shaft tube
- Fluids in everything but transmission
- Oil pan gasket and O-ring
- Spark plugs
- Spark plug wires
- Steering column bearing
- Steering upper intermediate shaft
- Shift lever boot
- Cabin air filter
- Pioneer 2DIN stereo
- Image Dynamics speakers
- Backup camera
- New key fobs
- Energy suspension torsion bar mounts
- Replaced roof antenna that was missing
- Upgraded alt to battery wire to fused 4AWG
- Replaced idler pulley bearing
- Adjusted parking brake
- Front rear brake pads
- Front rear brake hoses
- Variable power steering bypass
- Power steering fluid
- Added power steering filter
- Rebuilt steering box
- PCV
- Fuel filter (FFV)
- Rear pinion seal
- Serp belts
- Amplifier bypass harness
- Bilstein shocks (front)
Took me couple hours............
