I had a good time at the wrecking yard looking for a unicorn, I just didn’t realize it WAS a unicorn- the hatch glass from an 05-06 that’s the new design. Now I see what you meant @Tonyrodz about not being able to search for it. The guys there were sure they had one, it showed on their computer that it was with no surround. An 06 Yukon. And they had an 05 Tahoe they said had one. I looked at the 05 and about 8-10 others (not sure what years they were) but they were all the old style. The 06 was buried in blackberries but dude said no problem. He cut a path around the back of the truck, took a look and said “it’s the right one I think”....I looked and it wasn’t. The office guy said here’s the RPO code for that glass, then said never mind there isn’t a different one for that style. Sucks.
PG01
Up here to the right
Damn i miss walking around junkyards...
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
I just checked and there is no RPO code for that glass. Other then RPO# AJ1(DEEP TINT)
GM#15777670 APPLIQUE, L/GATE UPR (BLACK) (TO BE USED ON THE NON-ENCAPSULATED GLASS W/O BLACK MOLDING AROUND THE EDGES) CK1,2 (06) (X88,Z88) 2005 - 2006
Lists for $521
GM#15847108 GLASS $653.35
(Without deep tint)
GM#15847109 GLASS $883.88
(Deep tint)
Bombsquad85
Northern VA
Well I had the exhaust work done today and decided to remove the 2 cats. Soubds pretty damn good and I noticed an increase in the butt dyno. I'm convinced the passenger side cat was super clogged. I also used some 02 antifoulers and no codes (other than mt P0102 code that popped up last week). I can never go more than a week without a code....
Any suggestions for P0102? The maf sensor is brand new
Lists for $521
(Without deep tint)
(Deep tint)
Nope, that’s what the dude said too. AJ1 is the only one that applies to that glass but it’s just the privacy RPO.
There’s a TSB for the wiring connector due to the wire being broken inside the insulation right where it bends. You might solder in a new pigtail but make sure to solder and use heat shrink. Sometimes you can check by pulling on each wire and see if it stretches where the wire inside is broken.
mohammadamlih
