TheAutumnWind
05Single
afraid of the dark
finally decided to replace the burnt out fog. ( did replace them both, but this pic shows the comparison) Matches color temp with headlights and switchbacks much closer. Not a huge difference in output compared to 899s. Didnt take it on the road to compare unfortunately.
Went with these:
https://www.amazon.com/gp/product/B084YZNTPK/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
Well that took forever , I figured you already had some. Matches nicely !
druiddonn
I added three USB ports to the back of the cubby hole in my Denali center console two of them are for charging I'll take the power from the cigarette charger the other one plugs into the back of the stereo the cigarette lighter door now holds my subwoofer volume
And then I had to move the double USB the clear part of the internal structure
I want to extend the actual steel cable with the ball at the end. The cable that sticks out of the blue clip View attachment 253138
how far do you need to extend it?
you can make a bracket and it would give you whatever room there is before it stops when open
you can attach one end where the ball currently is then on your bracket drill a hole and make a slot to insert the cable, giving you an 1" or whatever you need
you could use some picture hanging wire also and just make yourself a cable as long as you wanted
Wonder what Dave has up his sleeve now:D
conrual777
