replaced the blower resistor and blower resistor harness on the 05, but still has same issue as the old one, adjusts fan speed 1/2/3 fine but 3/4 are both nigh speed and stays at high speed until you turn it off and start over so I am thinking it must be the control panel.
re-installed some led bar fog lights I had for it and fixed the bracket so they would stay where they are supposed to, before they would turn and point the wrong direction because the bracket was worn out.
and discovered the steering gear box is leaking looks like it's probably the output shaft, it needs a new pitman arm anyway so probably going to try and find a dry used one at the junkyard and need to buy a pitman arm puller
Two steps forward, one step back. Pretty normal lol.
Boyce0183
