915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
On the drop spindles that are being sold, do they all require the use of 17" wheels or bigger. So since I'm on 16" I can't use the drop spindles
ks03
Fool Excess Member
AFAIK yes, the lower control arm stays in the same spot and they move the hub up as high as they can in the knuckle. With 17s it looks like you have to cut the end of the lower ball joint stud off or else it would hit the wheel… and then sounds like they want you to hammer over the threads to secure the nut….which sounds a little sketchy, so even though I’m on 17s, I’d think about 18s or larger if I was going to get drop spindles
I mowed the lawn then washed The Beast and cleaned the leather and interior trim after hauling a couple tons of old bricks and telephone poles to recycling. I still need to vacuum it and then the Ceracote trim coat came so I need to do 576AA015-2A32-492E-A8C9-AB7ADDB2FE64.jpeg 3D67F624-7F4D-4E7E-AAB3-8A0A2AF5E137.jpeg that. But next up is to wash The Machine. Ran out of daylight.
Jalexa5834
