Leo1103
Got a lot done in the past 2 days. 5% tint all the way around, finally got the window wood trim pieces, changed the bow tie to black, remote start and installed new door
Where did you get the steering wheel sticker?
don't think it is a sticker, there is a metal cover that you replace by disassembling the airbag install the cover then put the airbag back together.
I just cut the tabs short and used some RTV in the center. No messin with the airbag for me. But that was for the center metal part which came in gold. Then I did buy a black sticker from Ebay.
Derick
Indy Suburbs
Took the burb in today to get it aligned after all my suspension work.
And of course, there's a problem. Eff me running.
Folks, if you monkey with the upper control arms, make sure all your alignment cam pins are in there when you reassemble. My drivers side, rear control arm bolt was seized in there pretty dang good, so I was beating and prying on that thing for the better part of an hour. Well throughout the beating process, I must have popped out that alignment pin. I thought they were all just part of the assembly, didn't realize they were removable. Probably a good thing they are though. Anyhow, took it in to get aligned, and it wouldn't stay put to get a proper alignment. dammmmmmmmmmit. So, gotta get some new pins this week, fix that, and get it aligned again.
tony97218
