HiHoeSilver
Away!
Chicago
I noticed more water dripping from the left rear again. So I started pulling the lower door weatherstripping and this happened.
I finished pulling the rubber off, and pulled the "drain plug" out of the door. There was a LOT of water in there.
I'm guessing this is from a bad window seal. I dont see any other way for water to get in there. Any other ideas?
This is totally normal. Conventional wisdom regarding these trucks says to take those plugs and throw them as far as you can.
Chrismnj
NJ
There is a small drain hole in the corner. It's right above where the seam from the door skin is folded over.
Btw, I removed the rear most plug from each door and kept them out.
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
I am not really sure about this drain hole at least didn't see it on mine, I meant lose the plugs. like @HiHoeSilver said
Chrismnj
NJ
The other three doors were dry, btw.
My house is located right on the water, we get some really bad northeastern storms, wind driven rain gets in to my driver door like crazy more driver side than any other door, I guess because of this window being used the most maybe?
Chrismnj
NJ
Fu$k that!! Only if there's no humidity.
Agree, I am actually buying a condo in that new 17 story building in asbury as an investment, Nice breeze up there and less humidity at this elevation.
BG1988
Always LOTS and lots of water from the TWO mufflers....
enough to fill up a water bottle
