I saw that link after i went looking for it. I did the resistors and such with my NBS, had them in there for ...... oh lord...like 10 years or something. Was still in it when I traded it in. Seemed to work just fine, I just wanted something a little more permanent and proper for this truck
Add the jumper underneath the fuse box then. All you’re doing is triggering both factory relays at once. There’s still fuses and relays for safety. I just want to make sure the wire doesn’t get hot but it seems fine.
St. Louis
Actually did Tahoe stuff this weekend.
Yesterday I did the air cabin filter retrofit, super simple and easy.
Today I wired in this relay
full
so now my fogs stay on when I turn on the high beams
How did you wire the relay?
St. Louis
At first they were using a diode but were having problems and they ended up just using a jumper which is what I used. The wire isn’t getting hot but I’m gonna leave it temporary, in the top of the fuse box, for now until I’m sure it’s ok and then I’ll pull the fuse box and add it underneath so it’s clean. The only thing I noticed was the fog light indicator in the cluster doesn’t come on unless you actually push the button but other than that, the fogs come on with the low beam and high beam and it doesn’t interfere with the high/ low beam function or flash to pass.
https://www.tahoeyukonforum.com/threads/figured-it-out.7997/
Doing it this way with the wire in the fuse box, do you still have control of the foglights with the switch, or do they just come on all the time ni matter what?
The fogs are on anytime the headlights are on and vice versa. All it’s doing is jumping the fog light relay at the same time the headlight relay is triggered or vice versa. Both relays get triggered from the same signal. The fog switch is momentary, it doesn’t stay pushed in. It just sends a signal to the bcm, which turns on the relay. The headlights will come on if you push the fog button, in which case the fog indicator in the cluster comes on. But if you just turn the headlights on or if they come on automatically the indicator doesn’t come on when the fogs come on.
So I guess you could say you can control the fogs with the fog light switch but it will turn the headlights on too. But I can’t picture a scenario where I would want the fogs on without the headlights.
One last note- the reason I noted the fog light switch is momentary is so you know that if you push in the fog switch and it turns the headlights on ( you don’t need to ever do this btw), when you turn the ignition off it goes back to all lights off when you start the engine again -unless the auto headlights turn everything on. The switch doesn’t stay “on”.
They’re wrong where they say the method I use piggybacks your fog lights on your high beam fuse. The headlights have a relay which is powered by a fuse. The fog lights have a relay which is powered by a fuse. The relays are triggered by a ground from the bcm. All I did was tie both ground triggers together so both relays come on with a signal from either output from the bcm. I don’t like it when someone states they have a “proper” way to do something but in reality don’t really understand the circuit they’re modifying. Now you have two fuses and two relays for your fogs. You only need one, the factory one. That just makes it over complicated. To me, that way isn’t proper. Or cleaner. What is clean is jumping both triggers from the bcm together. I’m gonna figure out which two wires those are and do it that way. Should be pretty easy.
esesober
