89Suburban
Bull in the china shop
SE PA
Snap a pic of the bottom edge of the door with it open. Hows that rubber flap/seal that wuns along the inside bottom and covers the drain plugs?
It’s there and in tact. I’ll get a pic shortly.
St. Louis
When I close it it is nice and smooth latching action. I don’t notice any dragging or lifting as the latch engages the striker. You would think with the miles this thing has it would actually be hanging lower.
Do the bolts on the hinges look like they've had wrenches on them/toolmarks?
Is there something I can put on the seal to shut the door and see where the gaps are? Some kind of marking material? Chalk??
Chalk should work, get a bottle of the blue stuff for a chalk reel and you can rub it on the door around the perimeter where the door meets the seal, close the door just hard enough to latch, and open it. Clean the seal first so it shows up good.
Please esplain.
I'm not sure of the exact procedure, but while fixing my own car in my friend's body shop I heard him mention that more then once about different cars coming in. I've seen him actually yank and push/pull the entire door while it was on the car to get it aligned--the body lines to match up. How do your hinges look? Any paint cracked or flaked off?
St. Louis
Some kind of inner cord? Yeah that’s how it came. ****** up aint it?
I've seen that inner cord thing on the rear liftgate weatherstrip on my 2001. It's supposed to go into each other (one is a tube and the other is solid) and help keep the seam together. It's usually inside the weatherstrip. Maybe with it making it's way out from underneath is what's causing your problem?
St. Louis
OK, maybe that's not what I thought after looking at it more closely.
Did your new weatherstrip have the inner piece inserted to back-up the seam where they meet?
89Suburban
SE PA
Actually those little bingleberry strips are on the outside of the seal running around the perimeter. I did install that connector piece you are asking about. But when I looked this morning I didn;t see it. WTF? Maybe that is my issue. I don't think so though. Because if I move that striker in it seals up good.
...if I move that striker in it seals up good.
So, you need to make the bulb of the seal bigger. How about slipping something inside the bulb? Backer rod comes to mind. I don't know the inner clearance of that bulb part, but there are different sizes of this stuff. Might need to lube it a little. Just be careful that what you lube it with won't dissolve it.
Here's some 3/8":
https://www.homedepot.com/p/M-D-Building-Products-3-8-in-x-240-in-Backer-Rod-71464/202837935
1/4" on Amazon:
https://www.amazon.com/Closed-Cell-Backer-Rod-Roll/dp/B001OBTZ1E
