kbuskill
NE. FL.
Yes, the kit also comes with a new Remote Control Door Lock Receiver Module and the long range antenna, which we attached to the side glass in back on the driver's side.
Out of curiosity, does the RCDLR still work with standard key fobs?
I would assume so.
I am more interested in the extended range than anything else.
Monday, I went to do a side job and hauled my neighbor's welder. It's one of those diesel-powered welder/power plant machines on it's own trailer from an equipment rental place.
Averaged 20MPG at 70MPH towing it and with a few hundred pounds of tools in the cargo hold:
Also hit 204,000 miles. Oil change coming up in 1,000:
Yesterday, when checking under the hood while refueling, I saw that I had already began performing the slow coolant delete mod:
I was headed into town for a last-minute Christmas gift, and I still had plenty of coolant, so I pressed on lightly to keep the RPM low to minimize pressure in the system. What normally would've been an hour trip took almost four hours due to traffic. It did fine.
PG01
Up here to the right
WHOA......we’re twins.... those are the two ‘mods’ I’ve done...... oil change mod and slow coolant delete mod.......
Crazy.....
kbuskill
NE. FL.
Crazy.....
Ironic... I too noticed a very very small leak that appears to be coming from the top of the driver side of the radiator end tank.
Been looking at radiators but haven't decided on which one I will go with.
It is so minor it will probably be a while.
Yes!
The novelty of checking the fuel level and air pressure in the tires from the remote will be short lived I think! Visual confirmation that I locked it up for the night and the extended range especially is where our interests lay as well.
You looking at factory replacements or aftermarket ones? Unless there's an upgraded one (factory or aftermarket) that's a direct replacement for my factory original and for a reasonable cost, I'm just gonna get what lasted 200K miles. I haven't even begun trying to pin down a part number yet.
We're taking the Tahoe today to dinner at my brother's house 30 minutes away since we gotta haul large Christmas gifts. I'm confident it'll be fine.
How much did it weigh?
St. Louis
Do our radiators have the plastic end tanks that are crimped onto the ends with those aluminum tabs?
bobwit2bs
