St. Louis
That's near where I put mine. There was a small factory hole that I mounted the bracket to, and a larger hole just in front of it I could stick my hand in and reach the back of the bolt to hold a nut on.
The battery shelf comes in handy when draining. Mine has a small ball valve at the bottom and I just place a small butter tub underneath and let it drain while I'm changing the engine oil. 0b63a5d513801719af5576f6c82f9a40.jpg815bc0be9d2a0f1578a409bef0b62372.jpg
Have a drain valve in the bottom of it? If you haven't already, I recommend cramming a stainless Scotch-Brite scrubber in there. It'll increase the can's effectiveness. Of course, with the scrubber in there, you don't want to have to unscrew the reservoir to drain it, so a 1/4-turn ball valve in the bottom like what @gooffeyguy has would be really convenient.
Bigkevschopshop
Northside H-Town
It has the provision for adding the fittings for a valve.. I plan on doing it soon, Figured I would get it in, then add the valve and scrubber on next oil change... Plus it gives me a good benchmark for how effective it will be with scrubber and without...
No testing necessary- the more coalescing media it has, the more oil it'll catch. It's not like an air filter into the engine where you have to maintain at least a minimum amount of flow. You wanna filter as much as possible, even if it presents a decrease in air flow volume. You can't filter it too much and a loss in flow won't affect anything.
Mine consistently caught 2 ounces every 5,000 miles. After the scrubber, 3 ounces consistently.
Just Fishing
Can't fix stupid
Utah
I put one in on the vette on my avatar.
Was just an empty can, but cheap and fits a morso clamp.
Built my own baffles and put one of those scrubbers at the bottom.
Used a tube from the valve cover side to ensure the oil gets to the bottom of the baffles and would need to make its way up.
In the vette, #2 cylinder likes to get all gunked up with carbon, and a nice oily streak down the intake runner to that cylinder...
Fixed the issue with the catch can...
I'm sold on the idea afterwards. :beer:
It always catches nice dirty oil and water.
Not wanting to re-research the thing i bought the same thing for the hoe.
I'm not quite there yet but it did wonders for the vette, and since i have the engine totally clean i figure i might as well keep it that way. :cool:
On the vette i just remove the canister from the clamp and drain, but i'm looking at some method to easily drain it since that's a pita.
I thought it was 1/4in npt, but it's apparently something else... :rolleyes:
glad i own a drill and a tap set. :D
bdewitt205
