Bill 1960
Testing the Limits
Took apart the rear taillights, cleaned the sockets and replaced some burned out bulbs. Fixed a rattle in the dash (resulting from careless assembly / disassembly by previous techs).
Found a gizmo under the dash the Feds use to automatically record odometer readings at the gas pumps. Apparently when you're spending other people's money no convenience is out of bounds. Removed it.
Looks like I'll be replacing the big electrical junction block that mounts behind the parking brake. Some careless butcher of a tech broke all the mounting tabs on it.
Sparksalot
Bastrop County, Texas
I found out years ago these long curved pliers come real handy for pulling plug wires and the metal shroud, harbor freight win
they have a pretty good grip, came in handy many many times, I think this set is about 20 years old
Those would be handy!
The ones I grew up with had nylon jaws. The idea being to not destroy the wire getting it off.
I usually no longer trust the wires once they have been pulled off unless they are not very old that core material rips very easy anytime I have pulled them off even by hand I am not sure if I ripped one or not, it might stem from me just having bad luck with plugs and wires so many times I have done them and then a week later "misfire" :mad:
Good to know! Was planning to finally clean my TB (1st time in 13 years! Haha) and was going to track down the IAC valve to clean also.
My apologies for misinformation JustFishing! You’d think the older I get the wiser I’d get by not spreading info that I simply assumed. :doh2:
Yup- it's all-in-one now. Instead of the PCM controlling a separate electronic valve to adjust the amount of air needed for idle, it just controls the main throttle blade since it's electronic.
I pop the end off the coils then spin the plug end of the wire around a few times. Then slowly pull out on it as I work the end in a circular motion. Sometimes I have to grab the heat shield with some long needle-nosed pliers and wiggle and pull it by that.
Sparksalot
That’s what I did after the first two.
Sparksalot
I agree. With these I have no idea how old the plugs and wires are. Possibly original?? Plugs were 41-110, and wires were Delco 5146.
Wash114
