Dantheman1540
Lower ball joints are being a pain to remove. Hammer didn't work. Heat didn't work. Pickle Forks didn't work. Now using a ball joint separator from Harbor Freight. Worked fine on a stuck upper ball joint but we have been grinding away on the tool to make it fit the lower ball joint and ran out of time. The girls are busy with their social schedules you know!
So at this point the struts and half shafts are out, calipers hanging on S-hooks and the engine oil cooler lines are disconnected but not removed. The front differential has been lowered but I think we're doing to pull it tomorrow to make more room. The front bumper cover and lights are off, we found the leak that the dealer said was not there, the lower connection on the condenser is leaking green oil everywhere. Bought an AC O-Ring and Seal kit from O'Reilly and had them refund me the condenser I ordered.
Bought a canopy from Harbor Freight and have that over the hood area in case it rains, all exposed connectors are pointed down too. Canopy secured on three corners with old brake rotors.
I forget to check and did not know that the lower control arm bolts and nuts are 15/16ths. 23mm too small, 24mm a little loose. Hopefully they'll come off tomorrow.
Still haven't gotten to the motor mounts or transmission oil cooler lines. Sure wish I was in my twenties again, all of this stuff would have been done already! The Good Lord is giving me patience but I keep wanting more.
Dang really getting after it! Glad to hear your able to beat things with hammers again!
