No cats? Just cram as much muffler as you can under there. Gonna need at least 30" to get it "half-assed normal". I have 40" (22"+18", butted together) and it's about all that can fit. It's pretty tame, but still meaty when idling and cruising. She barks when you step on her, though.
Sounds reasonable. Right now that MBRP is just a straight through deal. Have any recommendations on a good/decent muffler? Also, would changing to a bigger non straight through have an affect on the tune or performance? It was tuned with this muffler in mind. Thx dub.
EDIT--I have 2 brand new Borla mufflers, but they're only 2 1/4" in/out. I assume using reducers would affect performance? I'm using the stock sized exhaust piping, which I think is 3".
The mufflers I have are a straight-through design. One has a center inlet/offset outlet, so it does have a slight "Z" path to it. Keeping with this design won't affect the tune or performance at all.
Factory piping, at least on my GMT900 is 2.75". You could do Y to split your current pipe into two 2.25" to go into the mufflers placed side-by side, then Y them back together afterward and continue out as a single pipe. But, I think that'd hurt the flow and overcomplicate things. I'm a fan of the Magnaflow clones from AP Exhaust (Xlerator series) because they seem to be identical in function and quality to the Magnaflow, but are half the price or cheaper. But, I can't say if the stainless is a lower grade or not and might not hold up as well in salt cuz that's not an issue here.
Here's the 40" of muffler crammed under mine: https://www.tahoeyukonforum.com/threads/growing-up-doesnt-have-to-suck.93510/post-1485217
I forgot about the cutout. If it weren't for that, I could fit another ~10" or so of muffler.
Thx Dub, I'm gonna check that one out. Sux about the Borlas. I've had them for 15 yrs. I'd love to use them on something. I bet they'd sound great with the long tubes.
1BADI5
DMV
Just curious- what do you have into that setup? Is it a lot cheaper than a Wilwoods front kit?
Well all said and done I will only be into the kit for just under $1500; the Wilwood kit for the 16" rotors was going to be about $2500
Calipers with hardware kit - $950
Rotors - $220
Adapters - $195
Pads - $50
Banjo bolts/washers - $10
1BADI5
DMV
Stock exhaust pipe on the 5.3 should be 2.5"
Rotors - $220
Adapters - $195
Pads - $50
Not bad, about $1000 less than Wilwoods.
Dflo92
