Had to crawl under the car three times today with it in gear to put the dam shift linkage back on so I could put it in reverse to park.
Parts are supposedly showing up tomorrow to fix that crup
You need this--Traxion 3-100-FFP Foldable Topside Creeper https://www.amazon.com/dp/B00QGXSODA/ref=cm_sw_r_cp_apanp_CkE3hUMeNJvKs
the_tool_man
Upstate South Carolina
Would POR-15 work? It pretty thick stuff, hates UV but I think it might seal the ends up enough and protect it. Just shooting from the hip..
I doubt that would wick into the crack, which is what was asked. However, it would make a good top coat. I have some cold-rolled steel bar coated in POR-15 that's been outside for 20 years and still looks good.
St. Louis
Just spray some Fluid Film on/into the area then repeat the application every 6 months when you rotate the tires {or whenever you have the front wheels off)
Not uncommon for the street side in salt country. I always theorized it was. Corrosion from under a wet brake pad that sat a couple days.
Oh yeah, I always forget about you guys in salt country. A completely different set of problems than I have to experience. Thats a new one for me there. Damn.
Smityinms
