Just Fishing
Can't fix stupid
Yours has a #2 thrust bearing? We might've found your problem. lol
Even the stock LMG, at 9.6:1 compression, benefits from 89+ octane. At least, during hot weather. If you lowered the CR of your 6.0 to something more suited for ~87, you'd lose a lot of the peppiness you have now, even with the tune optimized.
You can change the cam without removing the heads by removing the rockers and spinning the cam a few times to push the lifters up into the trays, then sliding dowels (5/16" works fine) into the oil galleys to hold them while you swap the cam. Since you already have your rockers removed, you could slap on them 1.8s. Just be sure of your geometries. Oh, larger than stock cams tend to sacrifice small amounts of low end for mid-and upper-RPM power. That's just physics. They need a higher SCR to achieve a net DCR to make up for the losses. So, keep your CR and quench where you're at, unless them 1.8 rockers put you in the PTV danger zone.
Lol no i replaced it once already.
rolled in place and was able to set and confirm endplay from under the truck.
And yeah, i don't want to change the config and how it runs.
