BigRed300r
Athens Alabama
I dedicated a lot of time to some mods on my Tahoe this weekend. I replaced my low beam halogen lights with one of HID Guy's kits, plasti dipped my chrome surround on my grille, tried to repaint my front bowtie (FAIL!), replaced my interior lights with LEDs, installed my holster under my steering column, and replaced a seatbelt latch on the driver's seat. Now I'm waiting on my rear door actuators to come in as well as the billet bowties I ordered. As soon as they get here I'll get to installing them too. Long weekend but I got it done. What did you do to your Tahoe/Yukon?
Fubar0715
Scott
Southern New Hampshire
I guess our prices up here are better than I thought.
E85 - $3.15
93 - $3.25 (edit change from 91)
*In other news, we woke up to 5” of fresh powder this morning with another 2-3” expected by tomorrow. Two weeks in Florida can’t get here soon enough. So @swathdiver make sure to tell your state to get its act together by mid-Feb.
That is so precious that you think Florida will get its act together. Being born and raised there-you know everything is a fantasy world and you are dreaming! :2cents:
Be careful pulling on the panel to close the door without those bolts in place. The panels break easily and they’re not cheap. If you break the main handle part, you can’t buy just that piece, you’ll need to buy an entire door panel.
Update:
Yesterday I found out that Autozone sells a bolt that fits the door: Needa 455940 (replaces GM 11570136). Now all I need are the trim pieces and my job is completely complete.
Update:
Those stupid little cover pieces are expensive. When I did a LT to LTZ conversion, I bought the door panels for about $80 apiece used and those 2 covers that each door needed were about $20 by themselves per door (new, couldn’t find used). Probably cost more now.
I've seen the armrest trim piece for about $15 and the handle trim piece for around $10, both on eBay. The problem is that they're insanely hard to find at that price. Other sellers have them listed for the same prices that you mention.
Since you've done door panels, you got any tips for getting the lock knob back on? I bought a replacement (really, whoever took this door panel off the first time did the worst job they could without actually breaking the thing ), but I can't get it to stay.
If you mean the tab you pull up and down to manually lock the door, just do it with the door unlocked so the rod is all the way up, that way the little locking tab has room. Then open the lock tab with a pick so it’s popped out, slide the lock button down on the rod until the opened lock tab hits the trim, and then push in the lock button. Here’s mine in the released position, ready to pull he knob off. As you can see, somebody was fighting to get it open at one point. Now that I see it again I’ll probably have to buy a new one. Crap.
I can get it to attach, but it doesn't sit flush with the rest of the trim when locked. It could just be that the knob I bought isn't strictly OEM.
Does that lock tab look just like my pic before you push it in? The bottom of it should touch the trim before you push it in. If it does, and still doesn’t look right then it must not be the right part.
alpha_omega
Michigan
I replaced the throttle body and sensor in my 11 Denali yesterday. Now the idle is all messed up. Been watching videos on Youtube on how to help it relearn. Really hoping I don't have to take it in to get it reprogrammed.
Were you able to get it to relearn without taking it in? I’m guessing you don’t have Tech2 or an OBD tool capable of doing a relearn?
Weird how some people have a problem doing that I have swapped and cleaned and replaced mine on several vehicles over the last 15-20 years and not once ever had any issue I even put the ls7 throttle body on my Denali and it worked perfectly
I could be wrong, but I think a big part has to do with the fact of disconnecting the battery prior to disassembly.
Very true…but regardless by the end of Feb the weather has to be better than anything we have in Michigan.
Dillion
