Just Fishing
Can't fix stupid
If you have oil coming OUT of the passenger side, you have problems or are staying at WOT for far too long. I'd Y the valley pan PCV and the original driver side PCV together and run them to two catch cans in series.
Luckily, I'm not.
but when I had the Tahoe apart after trying the high-volume pump, I noticed some signs of oil on the throttle body
It was probably just because i had the intake on its end while i replaced the crank and rebuilt the transmission.
No other signs inside of the intake tube.
So, i did the second catch can as a test to be sure.
Even under WOT, I have no signs of oil coming out of there.
However, on the driver side I have oil.
Doesn't seem to matter of WOT or just normal driving.
Approx. the same amount of oil per time driven.
And I have the updated valve cover + a .75 valve cover spacer.
Still blaming those stupid lifters.
I'm hoping it helps once I finally have the insane amount of preload figured out.
I'm just dragging ass since i want to go outside and do things this summer.
Those lifters were pretty much my only choice at the time when i ordered them... everything else was on back order.
What I wanted was ACDelco branded ones...
And I have been running the two catch cans in line with each other on the driver side valve cover.
Nothing is passing by the first can and getting caught in the second.
Thing that worries me is the carbon I saw on the pistons when I had the engine apart this last time.
Just making 100% sure it's not the fkn pcv.
