89Suburban
Bull in the china shop
SE PA
Ok toady's mission in this 90* humid ass swamp ass shit show is doing preventative maintenance and replacing the heater core tee's. Damn good thing I am, the outer straight connector nipple completely crumbled to dust in my hands. DAMN lucky on that one that it didn't happen on the road!!! Got brand new AC Delco replacements going in.
How in the Sam Hell are you guys getting that kind of MPGs. When I drove to Florida, running 75ish all the way down, I got no more than 16. I would not give up my truck but a few more mpgs would be nice.
Drag is your biggest hindrance. Mine's 2WD (less weight), lowered and on stock-size street tires on lighter-weight wheels. The engine's also modded and tuned accordingly. All the engine mods were selected to work together. The higher compression increases power/torque. The tighter quench promotes more complete burn (efficiency) and reduces chance of detonation which allows for higher compression and more aggressive timing. The cam increases efficiency (read: power) notably at cruising RPM, reducing engine load at that RPM. Because of the improved power at the cruising RPM, I can get the same MPG at 72 as I do at 65 despite the higher RPM and increased wind resistance. Of course, it starts dropping considerably after 75 and 80 MPH- something like 1 MPG for every 2 MPH increase. The semi-tuned exhaust reduces pumping losses but maintains scavenging. The 3.xx"/4.xx" drop while maintaining a rake (although slightly reduced from stock) greatly improves aerodynamics. The removed roof rack helps a little. Removed third row seats so that's probably 100 lbs of weight reduction. This is also with a 3.73 axle gear.
89Suburban
SE PA
Is it supposed to be black on the outside and white on the inside?
Geotrash
Dave
Richmond, VA
I was going to make a silly remark about always being pink on the inside but decided not to. Sort of.
You’ll notice that there is a slight difference in diameter of one of the pipes so they’ll only fit either the inlet or the outlet of the heater core. On mine, it’s black on the outside and white on the inside.
Fless
Super Moderator
Elev 5,280
On my '04 the white tee is closer to the engine, and the black tee on the passenger side.
Is that black o-ring (or what is that) supposed to be on the passenger side heater core fitting?
St. Louis
I don't think all the pieces are off of them in that pic. Looks like parts of the inner clips still on the core pipes
DT360
