St. Louis
I've never actually floored mine from a dead stop. I have gone about 3/4 throttle from a stop then rolled into it after getting going though. I'm always worried about breaking something since it weighs 6k lbs. Although it is AWD, so the power split is like 60 rear/40 front.
I have other vehicles I can drive if I feel the itch to launch hard and fast. Actually quite a bit faster than these pigs, lol
mikeyss
Longmont, Colorado.
Maybe that is why my Tahoe came with the 14 bolt 9.5" rear differential, to help keep things from twisting up too much. Being in high altitude, (5k above sea level), I don't really worry about breaking anything when I floor it from a dead stop since I'm losing like 20% of my power. Plus, I don't really drive it hard too often, I've been doing this for logging purposes.
It is nice that you have other vehicles to drive when you have the itch to launch hard and fast, so do I. But I also like the sleeper affect my 'pig' has. My build isn't meant to be faster than mustangs or corvettes, it's my daily driver that was rare from the factory, and now has some extra goodies.
the_tool_man
Upstate South Carolina
After fighting intermittent headlight issues with the aftermarket units I had (in my sig pic), I finally narrowed the issue down to a bad ground wire internal to one of them. Since I don't have the time or motivation to peel it apart today, I had to switch back to the faded, yellowed stock units. On the bright side I think stock headlights are less common than the aftermarket ones these days. I was getting tired of seeing so many Yukons with the same ones as me, lol. I'm not sure what I'm going to do. Choices seem to be stock, affordable crap that everyone else has, and HID retros at $1k.
avalonandl
Troy, MICH & Naples, FL
I have OE units with LED Sealights, work well. My RH HL has mositure in it.
the_tool_man
That's one good thing about the OEM ones. LEDs would fit. My aftermarket ones used H1 and H7 bulbs, which aren't as widely available in LED. I never did find any that even remotely fit without leaving them open in the back where water would get to them.
And it looks like you still have a lot of Torque Management left in the tune. Watching your vids is like watching mine with the noticeably slower RPM sweep until around 3,000 then it swings. I don't know the exact numbers, but even flooring it from a stop is about the same as going 75%. You're telling the PCM you want it all and it's gonna give you all it can, according to the tune. 100% commanded from the pedal doesn't equate to 100% throttle angle. Any further pedal travel is just reiterating to the PCM you want maximum launch but you're gonna get what it's programmed to give. Once moving, the 75% to 100% TA is more for determining the up shift. I'd say you're safe.
Running in our respective locations, you'd probably run .5 faster than me. If you came here, you'd drag my ass. Any plans to put it on the track?
St. Louis
The RWD Denalis also have the 14 bolt 9.5" rear
mikeyss
Longmont, Colorado.
I agree, I feel that there may be a lot of TM in my current tune. I am going to send my files to Blackbear this week, and now that my trans is new and built to handle at least 700 HP, maybe I'll be safe having the TM turned down. I also noticed when I'm driving at 50 and drop the hammer, it only downshifts to 3rd, not 2nd.
Firefiterp
