1BADI5
DMV
Actually it was very easy, once you get the shaft off mark the nut and the shaft so you can get it back to the right tightness. Remove the nut and washer and spray with pb blaster then let sit for a few minutes, then you have two choices, either tap it off with a hammer (which is what I did) or use a puller. After that just pop out the seal and tap in the new one, and reinstall everything. It took me less time to change the seal than it did to put in one u joint.
Nice, i hadn't even looked at Mitchell yet. Good to know it will be a quickie job when I swap the transfer case out.
DallasTahoe
Not gonna lie I was kinda nervous about it but it really wasn’t a big deal like I thought it would be.
DallasTahoe
Did some preliminary fab work for an easily removable and inexpensive barn door mounted Jerry can mount, got it mostly done, a few tweaks here and there and I’ll be ready to do some Bedliner on it to finish it out
DallasTahoe
Got my auxiliary fuel tank setup done pretty happy with it, especially since it was cheap and it’s removable 6478f9a43ce3b658e53269670f826fdc.jpga72e58ac474a4731072b109307eb0957.jpg
My99Yukon
Looks great Dallas! Sometimes life gets busy, the mod works and those interim fixes become permanent. You do some great work.
ghettocowboy94
