th3 shifty
Utah
welded in new cats, found the reason my A/C would only hold a charge for 3 days, effing place i took it to left off a gasket on compressor... morons, installed a new CD head unit and front door speakers
TheAutumnWind
Got te dreaded low volt light today. Made it home on battery power only tg.
Swapped in an ad244. Seems to work for now.
Had to get a longer belt and a 3" 3/8 bolt and nut. Had the plug already and resistor for excite wire. Wired up a sense wire to distribution block.
th3 shifty
Utah
changed the starter to a Brand new AC Delco i picked up on Amazon for $95 free shipping.. "VatoZone" wanted over $240 for the same one
also changed out my 4 shocks to Rancho, just gone done ordering new driver seat foam, new carpet from LMC as well as door hinge and roll pin kits, new front splash shields, textured door handles, and lower door sill trim.
next month im going to do the seat covers for the driver and passenger seats
TheAutumnWind
View attachment 228341 View attachment 228342 View attachment 228343
Got in an overdrive alternator pulley 49mm. I was able to go back to the stock size belt, its on the tight side, but there is still adjustment left in the tensioner, and the belt is nearly brand new so it'll likely stretch a tiny bit. Was able to return the bigger belt, so it was actually cheaper to get an overdrive pulley. Considering the rpm range of the tbi is like 500-4000 rpms I doubt I will see any disadvantage of running the overdrive pulley.
Volts sit right on 14v on the gauge @ idle now with max a/c and (stock) stereo cranked & lights on. Before I was seeing >12v.
TheAutumnWind
Damn ICM is crapping out again. Its only been like 1000 miles. It dies if I let it sit and idle in 100+*F
Ponied up for the ACDelco and MX5 this time. Do people not relocate these things on these rigs? Seems like a major weak point on the TBI trucks
th3 shifty
Utah
Finished putting on the Rancho RS5000’s, now working on the new 7 blade trailer harness install.
Next week I do the new carpet and seat leathers
tony97218
