Squirrelsmith
Would typically refer to the turn signal stalk.
Yep thats the one. When my wipers went out so i bought that plus a wiper motor assuming one would fix it. Tried the motor first since it was easier and that was it. Never got around to returning the switch so i decided to do it to get some of my white lettering back. Probably not worth the effort just for cosmetics.
Merc1973
Maryland
Inlaws have a 94 k1500 suburban. I installed All AC Delco Professional pitman arm, idler arm/bracket, tie rods, sway bar endlinks. I used the string method for toe until i get an alignment. Today is rag joint and adjusting the steering gear to reduce slop.
liquify33
Houston
Replaced:
Lower intake manifold gaskets
Spider conversion
Idler pulley & Tensioner (noisy)
Distributor (broke the plastic)
Plugs/wires
Coil
ICM
Crank position sensor (got dirty with the above)
I lost 2 days chasing that damn sensor failure from letting coolant run into it while draining the radiator with the clip unplugged. The ground strap for the ignition system (by the crank sensor) was also deteriorated and broke.
Even pulled the upper intake a 2nd time to verify my work in there, only for the easiest sensor to replace to be the culprit!
I jokingly told the wife that next time I could probably cut my time in half!
Squirrelsmith
the quest to drive in a straight line, i'm doing the same right now. I'm replacing the rag joint with the flaming river universal joint, it's supposed to be a big improvement
liquify33
Houston
They won’t warranty my alignment due to steering slip. I know the tie rods are shot, it was on the list before upper intake gaskets took a dump.
dkknaebel
Keeping LKQ in business
St. Petersburg, FL
I actually solved a problem on FrankenBetty this weekend. My a/c compressor was randomly shutting off. After reviewing everything replaced with that system and some help from the Google, I determined that the pressure sensor on the accumulator wasn't new, it was the old one. Replaced and viola! System runs like it should. I was also able to score a pristine dash at Daytona's Turkey Rod Run in the swap meet and when we replace that, I think we're going to look at my blend doors to be sure they are lined up and actually working so that I quit getting air out of top, middle and bottom vents. I think that project is occurring in two weeks.
Chadricckglenn
