Kelsda
New Jersey
Removed rear bumper blasted and powder coated black looks great.Pulled off trailer hitch was going to have it blasted and coated but a lot off rot inside so ordered a new one, hitches are like boat trailers rot from the inside out. Then stuck my hand into this bag of potato chips.looked very minimal before I touched it Inside looks new so now I’m committed to do rear fender flare removal. A decent amount of interior removal to access flare studs.
YukonGTmaster
I was in the exact same boat with my 97 GT in the summer. I ordered every replacement patch panel available from LMC and Mills Supply. The hood and front fenders have to be removed to get the front flares off. It is a PITA, but I hope you can keep her on the road! Post up your progress.
Kelsda
New Jersey
I can prep everything, just don’t have the skills to do finish body work. No shops here want this work. They want quick insurance claims. I have seen your work looks great. I will order parts after assessing damage. Mock it up tack weld and most important find someone to finish. I believe you only painted what was needed.that’s what I would do
YukonGTmaster
Yes. I just painted from lower body line down. You can’t see the tape line unless you are really looking. Post up your progress. I would like to see how it turns out.
YukonGTmaster
My Rear Defrost at my Barn Doors was not operating. I took red Scotch Brite and isopropyl alchohol to the contacts. After they were polished, I put electrical contact corrosion inhibitor on them. The defrost is working now, but I can’t get the rear door lock/unlock button to activate the rear doors. If I press the rear button, it will actuate the front doors. If I press the buttons at the front doors, they 397ED20A-7867-4AB7-98F7-896FB487BF01.jpegA3C2A603-ABB9-4605-B81B-EBF118E4923E.jpegwill lock and unlock the barn doors. If I use my key at the barn doors, the cylinder is very hard to turn manually, I tried to purge the lock with lubricant. I will leave it, and come back to it. I don’t want to snap my key off in it.
My Rear Defrost at my Barn Doors was not operating. I took red Scotch Brite and isopropyl alchohol to the contacts. After they were polished, I put electrical contact corrosion inhibitor on them. The defrost is working now, but I can’t get the rear door lock/unlock button to activate the rear doors. If I press the rear button, it will actuate the front doors. If I press the buttons at the front doors, they View attachment 361824View attachment 361825will lock and unlock the barn doors. If I use my key at the barn doors, the cylinder is very hard to turn manually, I tried to purge the lock with lubricant. I will leave it, and come back to it. I don’t want to snap my key off in it.
Did you use powdered graphite for the lock cylinder?
Rome58
