my 1999 tahoe in short
Well I bought my basically stock 1999 tahoe back in December 2011 from a friend of the family for $5000 with $97k on it and a lot of work done to it from the previous owner mechanically. I cleaned it up and painted the stock wheels and here is how she sat Jan 2012
I did some work over the spring/summer
- New ac lines, compressor, dryer, orifice tube and refridgerant
- New front calipers, pads, new rear drums, shoes and springs, bled all brakes (they still sucked)
- New plugs, wires, cap rotor
- New radiator
- New 4wd pushbutton
- New fuel pump and locking ring
- New oxygen sensors
- New Magnaflow catalytics converters
- New knock sensor
- New Thermostat
- New belt and tensioner
- New battery
- New Starter
- New work truck grill with tinted headlights and turn signals
- Used rock guard
- New windshield
- Used 72 watt each LED offroad lights ($125 bucks a steal)
- Used Outlaw II 15" wheels with 33" BFG ATs 12.5 ($300 bucks another steal)
- New shocks, rear shocks have coil springs to fix rear sag
- Added 2" blocks in the rear and a torsion bar crank in the front
- Basic tune using hp tuners ( still in progress, once I get new front o2s put in I will be dialing it in more)
I then go ambitious and added a 3" body lift from summit and some flexy flares and a nice diamond deck filler plate on the back
I then got a little over zelous and get stuck while hunting one day what I thought was solid ground was frozen marsh, I learned the downfalls of the open differential very quickly.....
Around the same time I almost rear ended someone that stopped short in front of me because the brakes suck on these trucks, I did some research and ended up with
- new hydroboost power steering pump
- new hydroboost power steering lines
- new hydroboost unit
- new master cylinder from 1 ton
- ebay hydroboost adapter plate for astro van
I also decided the open diff had to go. I upgraded it with:
- new detriot true trac differential
- new outer wheel bearings and seals
- new carrier bearings
- new fluid
- summit racing pinion bearing support diff cover
and here she sits after it all! Oh yeah I forgot to mention, I did everything myself, built not bought baby
![photo-1_zpsa0c69826.jpg photo-1_zpsa0c69826.jpg](https://www.tahoeyukonforum.com/data/attachments/136/136386-80666111372892b6515c5095d40f44d1.jpg)
