What do I need to reset codes?
exp500
Glad you are getting it worked out! One more reason I recommend the FSM before maintenece.I will probably be wrong again sometime.
Eman85
Also does ABS codes which showed me 'Front Right Wheel Speed Sensor' errors and a couple of others. Might look into what it takes to deal with that.
Not really concerned about the Evap code since it doesn't affect operation and we don't have testing here.
As shown below, 8th digit is 'R' for 5.7 Vortec V8
Frt. wheel sensor problems are many times from worn hub bearings or rust under the sensor. You can remove the sensor and clean where it mounts.
Mean_Green
Mean_Green
If I'm going to take it off, I'm going to have a new one on hand and replace it. Rock and a couple of other places have them for under $20
BUT, I likely won't be doing anything until October when it cools down again.
iaminfiji
